Undefined value found.
when I solution emw, it has a error :
- Detail: NaN_or_Inf_found_when_solving_linear_system_using_SOR
what's this message meaning ?
Thank you!
3 Replies Last Post 7 mai 2013, 22:17 UTC+2
Posted: 1 decade ago 26 mars 2012, 16:59 UTC+2
The first thing to do is to check the log file.
Posted: 1 decade ago 27 mars 2012, 12:24 UTC+2
Ok, I will check that, and thank you!
Posted: 1 decade ago 7 mai 2013, 22:17 UTC+2
Hi Jaap,
I am simulating a nano antenna in RF module and I get this error:
I also simulated the same model in 2D axisymmetric with the same frequency and the results were fine. Since I needed to use a different E-field as my source and the model was not symmetric anymore, I had to use 3D simulation. Moreover, I had some difficulties in meshing but I finally found a way to do the meshing without any errors. However, I only can change my mesh elements a little.
Since I used very dense meshes, do you know why I see this error? and how I can check the log file?
Thank you.
Hi Jaap, I am simulating a nano antenna in RF module and I get this error: Undefined value found. - Detail: NaN_or_Inf_found_when_solving_linear_system_using_SOR I also simulated the same model in 2D axisymmetric with the same frequency and the results were fine. Since I needed to use a different E-field as my source and the model was not symmetric anymore, I had to use 3D simulation. Moreover, I had some difficulties in meshing but I finally found a way to do the meshing without any errors. However, I only can change my mesh elements a little. Since I used very dense meshes, do you know why I see this error? and how I can check the log file? Thank you.
