Setting the unit of the parameter in Matlab LiveLink Comsol 5.4
I need to define the unit in Matlab. Therefore, I used the command obtained from LiveLink User's Manual 5.4 at page 150: something.set(property, [num2str(<value>)'[unit]'])
I applied to my code as:
x1=0.1;
model.set('a', [num2str(x1)'[mm]'])
(I wanted to assign 'a' value as 0.1[mm] )
But, I had an error: Unbalanced or unexpected parenthesis or bracket. When I add a comma after the value paranthesis, again the same error occurs.
Can you please help me abaout this issue? Thank you, Mervenaz
2 Replies Last Post 30 nov. 2020, 15:41 UTC+1
Posted: 5 years ago 30 nov. 2020, 15:29 UTC+1
Hi, Mervenaz. You need to add a space between num2str(x1) and '[unit] '. Just like this: for parameter, model.param.set('t0',[num2str(t1) '[s]']), or for boundary condition, dl.feature('pr1').set('p0', [num2str(pinj) '[MPa]']).
All the best,
Songcai
Hi, Mervenaz. You need to add a space between num2str(x1) and '[unit] '. Just like this: for parameter, model.param.set('t0',[num2str(t1) '[s]']), or for boundary condition, dl.feature('pr1').set('p0', [num2str(pinj) '[MPa]']). All the best, Songcai
Posted: 5 years ago 30 nov. 2020, 15:41 UTC+1
Hi Songcai, It worked. Thank you so much !! Best, Mervenaz
