simulate two air bubbles intergrating in the water
what are the steps should I do to simulate two air bubbles intergrating in the water using comsol 4.2 ?
I am firstly contacting with comsol 4.2. Thank you.
Should I use Two phase-flow ?
1 Reply Last Post 9 mai 2012, 18:44 UTC+2
Posted: 1 decade ago 9 mai 2012, 18:44 UTC+2
Yes, two-phase flow is the way to go with either the Level Set or phase Field methods. Check out also some of the similar models in the COMSOL gallery. There are two titled “Rising Bubble” and “Droplet Breakup in a T-junction” that I found useful.
Nagi Elabbasi
Veryst Engineering
Yes, two-phase flow is the way to go with either the Level Set or phase Field methods. Check out also some of the similar models in the COMSOL gallery. There are two titled “Rising Bubble” and “Droplet Breakup in a T-junction” that I found useful. Nagi Elabbasi Veryst Engineering
