Pressure constraint in laminar flow
Hi all,
I'm trying to model dilute transport of a chemical species in laminar pipe flow. However, I keep getting the following error message:
"There is no feature constraining the pressure. A pressure constraint is required to specify the pressure level. Ignore this warning if the pressure is constrained using pointwise or weak constraints. - Node: Laminar Flow (spf)"
I specified the pressures at the inlet and outlet of the horizontal cylinder. Head loss is negligible. I've attached a zip file containing my simulation. Any and all help would be appreciated! Thank you
2 Replies Last Post 31 janv. 2023, 10:01 UTC−5
Dave Greve Certified Consultant
Posted: 1 year ago 19 janv. 2023, 12:08 UTC−5
I'm not sure what is going on in this model, in particular I don't understand the Symmetry boundary selections.
However- laminar flow problems usually require a Pressure Point Constraint at one point in the geometry. Also try Fully Coupled for the solver.
I'm not sure what is going on in this model, in particular I don't understand the Symmetry boundary selections. However- laminar flow problems usually require a Pressure Point Constraint at one point in the geometry. Also try Fully Coupled for the solver.
Dmitry COMSOL Employee
Posted: 1 year ago 31 janv. 2023, 10:01 UTC−5
HI!
Yes, but these boundary conditions are overrided with Symmetry node, that is used for all external boundaries, that's why there is no pressure constraint in the model.
Dmitry Lazarev
HI! >I specified the pressures at the inlet and outlet of the horizontal cylinder. Yes, but these boundary conditions are overrided with *Symmetry* node, that is used for all external boundaries, that's why there is no pressure constraint in the model.
