Circular Dependency Error: Modeling T-dependent BH Saturation in Frequency-Transient Study
Posted 26 janv. 2026, 09:08 UTC−6 3 Replies
Hello everyone,
I am working on an Induction Heating simulation using the Frequency-Transient study step. My goal is to model a ferromagnetic workpiece heated above its Curie temperature (Tc), capturing two nonlinear effects simultaneously:
1. Magnetic Saturation: Dependent on ∣H∣ (B-H curve).
2. Phase Transition: The drop in permeability to unity as T>Tc.
I attempted to combine these effects by creating an analytic function for relative permeability:
mu_r_combined(T, H) = (mu_r_T(T) - 1) * mu_r_H(H) + 1
mu_r_T(T): Interpolation of relative permeability vs. Temperature.
mu_r_H(H): Interpolation of relative permeability derived from B-H curve data.
The logic is to scale the saturation curve by the temperature factor, ensuring μr→1 when T>Tc.
The Problem: When I define the material property using this function (passing the magnetic field norm, e.g., mf.normH or similar, as the argument), the solver fails with a Circular Dependency Error.
Is there a standard workaround for this error in the Frequency Domain? Or is there a better way to implement "Temperature-dependent Effective BH curve" to avoid manually defining μr?
Any advice on the correct setup to handle this nonlinearity would be appreciated.
Thank you!
