using Rayleigh Damping
hi every one
i was modeling buddy floating. i was thinking to ad valye for i was modeling buddy (alfa and beta) any ideas how to calculte this factor ? or any hints to find out how its work
thanks alot
3 Replies Last Post 8 nov. 2010, 07:02 UTC+1
Posted: 1 decade ago 3 juin 2010, 18:47 UTC+2
Have you checked the pags 140++ of the smeug.pdf doc ? I believe that should give a reply, no ?
And do an indexed search of "Rayleigh Damping" on the docs, there are more in there, and in the other documents, even somewhere a matlab scripts to optimise the two variables
Have fun Comsoling
Hi Have you checked the pags 140++ of the smeug.pdf doc ? I believe that should give a reply, no ? And do an indexed search of "Rayleigh Damping" on the docs, there are more in there, and in the other documents, even somewhere a matlab scripts to optimise the two variables Have fun Comsoling Ivar
Posted: 1 decade ago 7 nov. 2010, 11:44 UTC+1
Hi Ivar,
I've checked the pages. I still think it's not that clear how to obtain the constants (alpha & beta). There is some information about damping in 'smeug.pdf' (pages 140-148, 199, 372). However, it seems that the procedure of the constant calculation is not clear. They address a reader to the Elbow Bracket example (smeug.pdf' pp 36-37). In this example, they assume that "the structure has a constant damping ratio of 0.1."...Actually, if we assume another number we will get different damping parameters.
I posted the question about this issue earlier (www.comsol.com/community/forums/general/thread/10886/)...
Please advise,
Stephan
Hi Ivar, I've checked the pages. I still think it's not that clear how to obtain the constants (alpha & beta). There is some information about damping in 'smeug.pdf' (pages 140-148, 199, 372). However, it seems that the procedure of the constant calculation is not clear. They address a reader to the Elbow Bracket example (smeug.pdf' pp 36-37). In this example, they assume that "the structure has a constant damping ratio of 0.1."...Actually, if we assume another number we will get different damping parameters. I posted the question about this issue earlier (http://www.comsol.com/community/forums/general/thread/10886/)... Please advise, Stephan
Posted: 1 decade ago 8 nov. 2010, 07:02 UTC+1
the thing is that most damping in structures are not a material parameter issue but an assembly issue (welding, bolting, crimping "sqeezing" ...) and for these there are only the measured values that are valid, all the rest is only hypothesis
Hi the thing is that most damping in structures are not a material parameter issue but an assembly issue (welding, bolting, crimping "sqeezing" ...) and for these there are only the measured values that are valid, all the rest is only hypothesis -- Good luck Ivar
