Andrew Prudil
Nuclear Materials
2 decades ago
17 sept. 2010, 16:01 UTC−4
It sounds to me like you should be trying to use a parametric sweep. Basically, you can define parameters which are like super variables and can be used as input for geometry and mesh (where normal variables will not be updated).
A parametric sweep allows you to tell COMSOL to run the same file with different input parameters each time. A simple example would be varying the thickness of a geometry from 1cm to 15cm in 1mm steps. I should warn you, that I don't know how the program will respond if changing a parameter results in vastly different geometry (such as two sub domains intersecting where they didn't before).
Parametric sweeps also support distributed memory architecture so you could have each computer on a network calculating a different set of parametric inputs.
2 decades ago
18 sept. 2010, 03:31 UTC−4
hi my dear
if possible plz help me
i want to sweep the lenght of my structure in parametric sweep, frist, i should define the variable that distiguesh the lenght, but i dont know how define it
or i dont know how define the parametric sweep
hi my dear
2 decades ago
18 sept. 2010, 03:35 UTC−4
hi my dear
You should define your variable in Global Definitions section.
[QUOTE]
hi my dear
[/QUOTE]
2 decades ago
18 sept. 2010, 06:34 UTC−4
hi
thx for answering
if i define the variable in global experssion, it is the correct idea for me.
but how can i allocate a variable to the lenght of steructure
for example i write variable 'a' in the global experssion and define value of it = 2 and then i drew a circular, after that in the radius of it i wrote 'a', then comsol told me ' unknown variable name'
plz help
best regard
hi
thx for answering
plz help
best regard
2 decades ago
18 sept. 2010, 08:18 UTC−4
and where is the global diffinition section?
2 decades ago
21 sept. 2010, 08:00 UTC−4
Hi, there are two questions in this thread. The first one is regarding cluster computing I assume (since you mention ML parallel toolbox).
To distribute a COMSOL computation in a cluster, you need a floating network license (FNL) of COMSOL to begin with. Please contact your COMSOL sales representative for more information about this license type.
The second question was regarding parametric geometries. Both parametric geometries and cluster computing is explained in this introduction exercise (see p 57-62)
www.comsol.com/shared/downloads/comsol_v4_building_model.pdf
When you are done with the model setup, you can save it as an m-file if you want to continue working with the COMSOL LiveLink for MATLAB.
Note that you do not need MATLAB parallelization through the MATLAB paralell toolbox to distribute the COMSOL computation, unless you also do MATLAB function calls from within the COMSOL model.
Kind regards, Niklas Rom, COMSOL
http://www.comsol.com/shared/downloads/comsol_v4_building_model.pdf
