Error Message Non linear solver did not converge at Time=0.005073
i am trying simulating a water droplet impacting on a flat surface with particles. initially for optimization i am trying to observe results only with a single particle which is placed directly below the bubble impact position. here i am using laminar flow level set module and particle tracing module. the issue is with the convergence of non linear solver. i used user defined mesh with extra fine where the drop and particle is to move .What changes in the solver setting or the model should i do to get convergence.
0 Replies Last Post 20 juin 2025, 17:26 UTC+2
Hello Chinmay Patil
Reply
